WAYNE'S WEB SITE
Date:  7-8-2008
Number of Hours:  9.50
Brief Description:  Final assembly work
Drill holes and fasten radio brackets, Loosen nuts and change out cotter pins on rudder pedals, tighten adel clamp on fuel line, add 2 more adel clamps on fuel lines, cable tie wiring under floor pans, repair floor rib, install floor covers, install screws in autopliot mounting tray.
Install data plate, fasten scat tubing to air vents.
Rib finally broke
Rib finally broke
Rib repaired
Rib repaired
