Continued work on flaps, adjusted hole for flap connecting rod, check flap travel and it meets specs.
Mount autopilot tray, cable tie wiring, trouble shoot fuel gauge reading problem, talk with Greg at BMA.
Ordered nylon shoulder washers to isolate fuel sender. Trimed center column sheet metal to clear headset jacks, install plate nuts for firewall passthroughs.
