I showed Dan from Sparkchasers what's left pitot and static line wise. I then finished the landing light and pitot heat wiring. I repaired the aileron servo connector and re-installed it.
I fabricated an avionics fan bracket and installed the avionics fan. I run the pitot line through fuselage and up to panel.
