Brief Description: Install elevator and vertical stabilizer
Busy day today. I got the holes drilled for the elevator and mounted it. I then put the vertical stabilzer in place and installed forward attach bracket. After lunch, Robert came over and we riveted the nav antenna doubler.
I drilled all the attach bolt holes but will not attach the vertical stabilizer since I wouldn't be able to get the plane out of the garage with it on. I've run out of 1/4" snap bushings so I can't finish running the wiring to the tail until I get some more. I did get the trim servo wiring run.
After supper, I replaced the switch in the copilot's handle from a toggle to a momentary. This switch will be used to cycle through the EFIS displays.
