Well the panel is back at SSF and hopefully the last changes. I will test fit again then get it painted before mounting components and radios. I called Honeywell about getting a SPDT pressure switch for the Hobbs and low oil pressure indicator. No joy, as they only made 2 in 2007 and they have the quick disconnect terminals. I now am looking for a sealed relay with mounting bracket. I believe that I have found an automotive style with 15A rating. I'll also need one for the electric fuel pump.
I found a 25 ft ethernet cable so now I can connect the auto pilot sevo controller. I really only need 15 ft but couldn't find one. Maybe I can get someone to reterminate this one.
I had to cut the aileron servo connector in order to run the wiring down the center of the fuselage. I used a solder connector to repair.
