Brief Description: Install breather tube and aileron servo
I'm still trying to finish the firewall forward stuff!! I installed the crankcase breather tube and wish I had put in the nutplates earlier. It's getting tight trying to get a drill against the firewall as well as countersink the hole for flush rivet heads.
After the breather tube, I moved on to mounting the aileron servo. I made a bracket to hold 2 nutplates for each side of the servo. Sure makes installation and removal much easier and a one man job. I had to cut the connect of one end of the aileron control cable in order to run it to the servo controller. I'll get to lay on my belly and solder that back later.
