Gus from Van's confirmed that I need the high pressure boost pump since I have a fuel injected engine. It was really tough working out the bend allowances for the tubing since it had to be flared before bending. I confess, there were several tries before I got it done. Plus I ran out of tubing. I need to run the tubing from the outlet of the pump to the firewall. I got the cover figured out and clecoed in place. I need to take it apart and layout the platenuts.
