Today was chopped up. Vic and I took the van in for brake repair, then off to IHOP for breakfast. Then by the church to make sure the masonry contractor was working. Finally home for a few hours to work on the instrument panel. I got the vent brackets made and ground the vents to fit. I then clecoed the forward skin on so that I could locate and drill the holes in the center support. Now, I can attach the angle bracket to it and the firewall.
Tight fit until you get all the excess plastic off
