I cut and fitted the wing tip. Had to take 1/8" off the edges and nose. Decided on removable tip using nut plates. Will have to order nutplates and screws. The plan is to go to Stainless Steel Fabricators and get mirrored aluminum for the nav and strobe light refelctors. Once the lights are mounted and the nutplates installed, this wing half will be finished until time to mate to the fuselage. Hopefully Jack can make it back next week so that we can rivet the left wing bottom panel.
