NEIL'S WEB SITE
Date:  7-11-2016
Number of Hours:  6.00
Brief Description:  Start of the Build
Finally ready to start building, I had in previous weeks built a 4x4 foot workbench and the build offically started July 11, 2016 at 12:10PM. I followed the instructions from the Zenith Plans.
Step one: used a file on all the edges to remove any burs from the CNC machine
Step two: Trimmed the Spar Doubler to match the bottom of the spar, used snips to cut and metal file to deburr the rough edges.
Step3: label the rib stations on the spar.
Step 4: Clamped the doublers onto the spar using handi clamps and drilled through predrilled holes on the spar into the doublers. Clecoed into place.
Step 5: Clecoed the rudder horn and drilled out #30 then onto #20 holes.
Step 6: Deburred all holes drilled both sides, each part.
Step 7: Drilled each rib to final size into the spar and deburred.
So excited to get started on the rudder
Drilling the Doublers to the Spar
Drilling the ribs to the spar (tail)
