Christophers Web Site
Date:  9-2-2015
Number of Hours:  9.00
Brief Description:  Rudder
-Glued gap seal templates to rudder
-Hot glued foam to rudder and sanded to contour w/20 grit floor sanding paper
-Glassed rudder with one layer of KR cloth on each side overlapping at the leading edge and one layer of deck cloth over everything
-Removed 1/2" of foam from trailing edge and replace with flox
-Cut out area around hinges to allow installation
- Sanded gap seals on stern post
-Added foam on fuselage sides and sanded to improve transition from fuse to rudder
