Christophers Web Site
Date:  5-31-2020
Number of Hours:  86.00
Brief Description:  Bodywork/Firewall foreward/wiring cleanup
5/1 2
Taped tail area as mold release
Glassed tail cover
5/2 4
Pulled tail cover from mold
Removed all pour foam
Trimmed tail fairing
Drilled/installed screws to fairing
Filled canopy/aft deck line
Filled tail cover
Glassed stub wing trailing edge sides
5/3 3
Sanded canopy/aft deck fill to contour
Sanded tail cover fill
Spot filled both
Fiberglass repair on canopy
Sanded cowling fill
5/4 3
Final spot fills
Applied two coats of smooth prime
5/5 2
Finished third coat of smooth prime
Commenced sanding it off
5/6 1
Sanding w/180 grit
5/7 2
Sanding
5/8 3
Finished blocking fuselage w/180
Glassed aileron end
Bent control sticks forward 30 degrees
Messed with stick grip wiring
5/9 5
-Mounted control sticks/routed wiring
-Sprayed 3 coats smooth prime to remaining parts
-Sprayed more smooth prime on fuse
-Started blocking fuse with 220 grit
5/10 1
More sanding
5/11 4
Finished sanding with 220
Spot filled defects with glazing putty
Started sanding down putty
5/12 3
Sanding
5/13 4
Finished lower fuse with 220
5/14 2
Finished spot sanding
Started prep for 2K primer
Glassed damaged aileron end
Started cowling bodywork
5/15 3
Finished sanding and spot fills
Prepped fuselage for 2K primer
5/16 3
Prepped and sprayed 3 coats of 2K primer to fuselage
5/17 3
Blocking w/320
5/18 4
More sanding
Touch up varnish on some wood
Fab hardware backplate f/speedbrake
Wire cleanup
5/19 5
Finished fuse with 320
75% complete with 400
Wire cleanup
Wired control stick
Wired USB charger
5/20 3
Started 600 grit
Last coat of varnish in spots
More wiring cleanup
Ran wire to speedbrake actuator
5/21 2
Finished fuse with 600
5/22 1
Started spinner fitting
5/23 3
Cleaned out garage
Fit spinner and drilled all holes
Installed all nutplates to spinner
5/24 2
Engine control work
Safety wire work
5/25 2
Made distributor wires
Installed distributor
Gapped new plugs and installed
Wired distributor to coils
5/26 2
Drained oil and removed oil pan
Installed new gasket to
