10/27 2 -More intake work -Fabricated right seat belt attachment 10/28 3 -Finished seat belt brackets -Cut and glued ply for speedbrake -Trimmed intake shroud and added pads for camlocs 10/29 4 -Cut speedbrake and riveted hinge on -Cut hinge brackets for inside -mounted brackets -Drilled hinge and mounted to fuselage -Riveted camlocs on intake 10/30 2 -Worked on speed brake actuator mount 10/31 2 -Clearanced seat for added brackets -Installed seatbelts and brackets 11/3 1 Speedbrake work 11/4 .5 Made dust 11/6 1 Cut and fitted right air vent More dust 11/11 .5 Speedbrake work Dust 11/12. .5 Glued upper bracket for speedbrake Dust 11/13 .5 Trimmed upper speedbrake mount 11/14 .5 Fabricated limit switch bracket for speedbrake 11/15 2.5 Cleaned out shop Microed upper left wing Glued limit switch bracket
