Christophers Web Site
Date:  11-11-2013
Number of Hours:  7.50
Brief Description:  outer rear spars
I've spent the past couple weeks working on the outer rear spars. I cut and scarfed the rest of the plywood and cut all of the verticals for the two spars. The first spar is all glued with the exception of the last plywood face. I also started marking the center spars to cut the airfoil taper.
Copyright © 2001-2023 Matronics. All Rights Reserved.
