Christophers Web Site
Date:  9-1-2013
Number of Hours:  8.00
Brief Description:  Elevator and right spar
Over the past couple weeks I worked on the elevator and right outer wing spar. I glassed the stabilizer gap seal and did an initial fill and sanding of all surfaces. I also cut all of the verticals for the right outer wing spar and glued it all together. After that, I cut holes in the fueslage and put the center spars through.
