Christophers Web Site
Date:  8-14-2012
Number of Hours:  0.50
Manual Reference:  pg 24
Brief Description:  Rear WAFs
I realized about halfway through making the main WAFs that my printer made the templates 1/8" shorter than they should be. The other dimensions are good so I will be shifting the drill points 1/8" to the rear to make everything line up right. There is plenty of space and this will make the main bolts line up where they are supposed to. I used a higher quality printer to print the rear templates, cut them out, and glued them to the blanks today. All of those dimensions came out perfect.
