Christophers Web Site
KR2S
Bodywork
4-4-2020
Body work and Paint
1/27 3
Microed bottom of right wing
Started block sanding bottom of fuse
1/28 1.5
Block sanding
1/30 1
Sanded root fillet to shape
Sanded gear fairing to shape
1/31 1
Sanding
2/1 3
Sanding
2/2 2
Sanding
2/3 1.5
More sanding
2/4 .5
Yep, more of it
2/5 1.5
Sanding
2/6 .5
Filled pits and scratches on wing
2/7 .5
Sanding
2/8 1
Filling and sanding
2/9 4
Flipped wing and microed top
Glassed gear fairings
Glassed left bottom root fillet
2/10 .7
Block sanding
2/11 2
More sanding
2/12 1
Sanding
2/13 1.3
Sanding
2/14 2
-Final sanded right wingtip filler w/80 grit
-Filled pinholes
-Filled right lower stub wing
-Filled right lower elevator
2/21 3
Sanded wing fill spots
Coated both sides w/smooth prime x3
Began sanding lower right stub wing
2/23 5
Sanded right bottom wing stub
Spot filled
Sanded bottom wing down
Spot filled lows
Sanded off spot fill
Glassed left wing stub
2/24 2
Finished spot sanding b/r wing
Flipped wing
Trimmed left stub wing glass
2/25 2
Sanded t/r wing and spot filled w/putty
Initial block down of left lower stub
2/26 1.2
Sanded wing spot fill
2/27 1.5
Finished blocking wing, ready for primer
Blocked bl stub wing down w/80 grit
3/1 6
Blocked stub wings and tail
Filled low spots
Smooth primed bottom fuse
3/2 1
Started blocking down fuselage
3/3 2
Sanding
3/5 1
Sanding
3/6 2
Finished prep work
Applied 2k primer to bottom fuse
Primed one side of wing
3/8 3
Block sanding primer
3/9 1.5
Primed other side of wing outside which fixed trash problem
3/10 1.5
Blocked both sides of wing to 320
3/15 6
Wet sanding
Glassed wing roots
3/18 2.5
Wet sanded wings to 600
3/19 2
Wet sanded bottom fuse to 600
3/21 4
Prepped garage and painted bottom fuse
3/30 5
Figerglass work
Prepped wings for paint
Smooth primed tail section
Blocked out tail, ready for 2K primer
4/1 1
Wet sanded bottom to 1500 grit
4/2 3
Wet sanded botom to 2000
Buffed paint w/Liquid ice
4/3 2
Masked off bottom fuse
Installed engine mount and tailwhee
Panther Home
KR2S Home
1602
Bodywork
408
Landing gear/brakes
Copyright © 2001-2023 Matronics. All Rights Reserved.
