Christophers Web Site
Date:  12-12-2019
Number of Hours:  18.00
Brief Description:  wing bodywork
11/16 1.5
Block sanding
11/17 1.5
More wing sanding
11/18 1.5
-Final sanded first rough fill to 80 grit
-Filled low spots with cabosil/micro mix
11/19 1
-Started blocking second coat
11/20 1
-more sanding
11/22 1
-Final block sand with 100 grit
-applied 3 coats of smooth prime
11/23 1.5
-block sanded with 180/220
12/2 1
Final sanded w/220
Glued in right air vent
12/3 1
Cut/fitted and glued in left air vent
12/4 1.5
Cleaned out garage to make room for new air compressor
12/5 1.5
-More garage cleaning
-Wired new 240 outlet for compressor
-Started soldering copper pipe for post compressor cooling
12/8 1
Shop work
Microed canopy frame
12/10 1
Wired new air compressor in
12/11 1
Touched up body work on wing
More sanding
12/12 1
Sanded off previously mentioned filler
