5/1 1.5 Taped tail area as mold release Glassed tail cover 5/2 4 Pulled tail cover from mold Removed all pour foam Trimmed tail fairing Drilled/installed screws to fairing Filled canopy/aft deck line Filled tail cover Glassed stub wing trailing edge sides 5/3 3 Sanded canopy/aft deck fill to contour Sanded tail cover fill Spot filled both Fiberglass repair on canopy Sanded cowling fill 5/4 3 Final spot fills Applied two coats of smooth prime 5/5 2 Finished third coat of smooth prime Commenced sanding it off 5/6 1 Sanding w/180 grit 5/7 2 Sanding 5/8 3 Finished blocking fuselage w/180 Glassed aileron end Bent control sticks forward 30 degrees Messed with stick grip wiring 5/9 5 -Mounted control sticks/routed wiring -Sprayed 3 coats smooth prime to remaining parts -Sprayed more smooth prime on fuse -Started blocking fuse with 220 grit 5/10 1 More sanding 5/11 4 Finished sanding with 220 Spot filled defects with glazing putty Started sanding down putty
