Christophers Web Site
Date:  8-26-2019
Number of Hours:  23.00
Brief Description:  Cowling work
5/19 2
-Bodywork
-Installed prop with spinner plates and rough cut spinner to clear prop
-Fiddled with compression on #6 and got 70/80 by moving prop a bit
8/4 6
-Sanding bodywork
-Cut cowling and foamed for intake
8/11 4
-Intake shaping
8/12 1
-More intake scoop
8/13 .5
-Fiberglass prep for intake
8/15 1.5
-Glassed intake
8/16 1
-Sanded inside in prep for glass
8/17 1
-Glassed inside
8/18 2.5
-misc wire cleanup
-Microed areas for bodywork
-Started inner intake shroud
8/21 1
Shroud work
Wiring cleanup
8/22 .5
Intake work
8/26 2
-Glassed inside intake shroud
