Christophers Web Site
Date:  5-6-2019
Number of Hours:  17.00
Brief Description:  So much sanding, and engine work
4/28 4
Worked on carb heat box and carb intake
Finished carb heat box
Worked on front cowling hinge
5/1 4
Microed cowling and fuselage
Mounted remote elt
Worked on carb intake
5/4 5
Sanded left fuselage and cowling
Cut/drilled and riveted baffling
Started installing silicone baffle material
5/5 2
Sealed up around baffling
Finished bearing oil line pass through
5/6 2
Microed right stub wing
Sanded vertical stab
