9/19 1 Trimmed excess glass Cut foam for wing tips 9/21 2 Glued and started sanding wing tips 9/23 6 Ripped off bad right wingtip Hot wired left wing tip Glassed both sides Glued in and sanded wing root fillets Glassed left root fillet 9/30 3 Right wingtip installed and sanded to contour 10/8 7 Glassed right wing tip Glassed right wing root fillet Made new trim tab Attempted to add micro filler to left lower wing. Ready to sand. Glassed aileron ends
