Christophers Web Site
Date:  3-27-2018
Number of Hours:  26.50
Brief Description:  Right wing
3/9 1
-installed fuel vent
3/10 2.5
- fiberglassed right fuel tank access holes
-cut out panel hole for transponder
-started working on transponder tray mount
3/11 3
-capacity check wing tank with gas. 16 gallons and no leaks!!!!!!!
-finished transponder mount
-mounted and wired iFly 740b
3/13 1.5
-wired current sensor
-started gluing foam on right wing
3/14 1.5
-sanded nose ribs to contour
-Made transponder antenna ground plane
3/16 2
-more wing sanding and adding panels
3/17 1
More sanding
3/18 2
And more sanding
3/19 1
More leading edge sanding
Mounted transponder antennas
3/20 1.5
-glued in trailing edge foam and sanded more
3/21 2
Finished trailing edge
3/22 1.5
Filled in gaps with foam and sanded
Started cutting fiberglass
3/24 1 wired transponder gps
3/25 2 glassed main spar back
3/26 1
Wiring
3/27 2
More EMS wiring
Drilled egt sensors
Copyright © 2001-2018 Matronics. All Rights Reserved.
