2/2 1 -leak check failed - made harness for remote compass 2/3 2 - made fuel line for left tank -made and mounted fuel selector bracket 2/4 1.5 Wired radio antenna cable Mounted air temp sensor 2/5 2.5 Mounted left brake and lines Made fuel lines for right tank First attempt at main fuel line failed 2/6 3 -last attempt at sloshing tank before total rebuild - made some fuel lines -More wiring - ran right brake lines 2/7 1 -random work 2/9 1 2/10 2 -finished fuel lines -Made rudder cable brackets
