Christophers Web Site
Date:  6-2-2017
Number of Hours:  15.50
Brief Description:  Starting right wing
5/28 2 attempted lower wing root fillet. Will do it again later.
5/29 2 cut wing free and trimmed trailing edge
5/30 3
-Flipped fuselage
-Worked on wing spars
-Made trailing edge fixes on left wing
5/31 3.5
Made airfoil tip template
Set washout and drilled wafs
Tapered spars
6/1 3
Made spar extentions
Glassed spars for fuel tank
6/2 2
Glued root and tip templates
fuel line bracket
fuel line bracket
left wing done
left wing done
setting washout on right wing
