5/19 1.5 - glued leading edge panels and sanded to contour 5/20 3 -finishing leading edge sanding - patched a couple spots - Filled and sanded wing gap - floxed in fuel cap - cut all of the fiberglass for wing 5/21 3 glassed top of wing 5/22 1 marked and cut wing free 5/23 1 removed wing, installed fuel bracket, and cut vent holes through ribs 5/24 3 Cut and glued in lower wing panels 5/25 2 Flipped fuselage and bolted wing back on 5/26 3 sanded wing to contour and cut fiberglass 5/27 3 glassed lower wing
