5/3 3 temp installed top with duct tape as a release and glassed two layers of 2" tape on all edges 5/4 1 more fuel tank glassing 5/5 1.5 glassed last top portion and center rib cutouts. Bottom ready for permanent install 5/7 3 glassed bottom and all corners 5/8 2.5 -finished up a couple spots that needed attention - cut hole for fuel pickup and started making line 5/9 2 -finished fuel pickup and bracket -soldered new wires to fuel sender -floxed fuel line and sender into tank 5/10 1.3 -floxed vent line in -glued two top panels in and made nose blocks 5/11 2 -filled tank with gas to leak check - fuel sending unit not working right, tried to unstick 5/12 2 -made longer fuel float arm to fix problem and reattached unit - fixed one minor leak and leak checked again - floxed top of fuel tank on 5/13 1.5 - fixed three leaks found on top - leak checked again, found another leak....repaired.
