4/23 1 made temporary template for root of outboard wing 4/24 1.5 -glued/sanded spar extensions -Temporarily glued root template -Cut foam for in-board tank wall 4/25 1.5 cut foam panels for wing ribs and shaped in-board tank panel 4/26 1 glassed spars with two layers in wing tank area 4/27 1 glassed spar extensions and trimmed fuel sending unit to fit 4/28 1 glued tip template and foam ribs 4/29 1 Sanded ribs to airfoil contour 4/30 1 cut ribs 3/4" below contour and cut upper wing foam panels 5/1 3 - cut lower wing tank panel - cut fiberglass for tank areas - glassed upper tank panel and temp installed 5/2 1.2 glassed rib sides and added a layer of deck cloth to top panel to catch any pinholes from first layup
