6/5 3 cut canopy frame rails and cut/bolted piano hinge to right side 6/9 2 replaced canopy hinge hardware with counter sunk screws and cut/sanded side foam for canopy 6/10 2 re-did right side canopy foam and fit canopy 6/11 3 prepped canopy and glassed aft deck 6/12 2.5 glassed around canopy 6/13 1.5 marked and cut out canopy frame 6/14 1 started sanding inside canopy frame 6/15 1 finished sanding inside canopy and floxed forward cut area
