-Glued plywood skin at rear right of plane. The tail is now closed out. -Glued in rear mount plywood/verticals for stab -Leveled aircraft fore and aft -Ensured tail was centered -Measured from foreward tips to main spars, a foreward center point, and the center of the stern post -Incidence was set by adding a piece of 3/32" ply under the rear spar/set at -.75 degrees -Glued in place with T-88 and then all measurements were verified again -Varnished area below stab with thinned out T-88 before installing
I also glued in the upper brace to set the seat back angle. It is ready for the shelf to be installed.
