Glued in rear spar, blocks on top of main spar and the blocks below the rear spar. I also glued in the last verticals and gussets where the horizontal stabilizer will mount. I also started filling in the front area with foam to get ready to install the cockpit floor and worked on the aluminum brackets for the aileron controls.
