Christophers Web Site
Date:  12-26-2012
Number of Hours:  8.25
Brief Description:  Horizontal stabilizer spars/templates
My first attempt at gluing my scarfed plywood for my main spar went horrible. I cut out the bad glue joint, scarfed the pieces again and then glued/clamped them. Then I started working on my horizontal stabilizer assembly. I spent time sanding and filing the templates for a while then decided to tackle the spars. I drew all of the dimensions on the spars then used a hand plane to get them down to shape. My hinges and composite material is on order from wicks and should be here soon.
main spar plywood being glued at scarf
All spars tapered
All spars tapered
