My first attempt at gluing my scarfed plywood for my main spar went horrible. I cut out the bad glue joint, scarfed the pieces again and then glued/clamped them. Then I started working on my horizontal stabilizer assembly. I spent time sanding and filing the templates for a while then decided to tackle the spars. I drew all of the dimensions on the spars then used a hand plane to get them down to shape. My hinges and composite material is on order from wicks and should be here soon.
