I glued in the lower compression brace yesterday and gave it a day to cure. Today I spray glued some 60 grit sand paper to my 48" level and spent a couple hours sanding the lower longerons to match the contour of the lower cross members. I followed it up with some finer sandpaper to smooth out the wood. The bottom is ready for the plywood to be glued on.
