I realized about halfway through making the main WAFs that my printer made the templates 1/8" shorter than they should be. The other dimensions are good so I will be shifting the drill points 1/8" to the rear to make everything line up right. There is plenty of space and this will make the main bolts line up where they are supposed to. I used a higher quality printer to print the rear templates, cut them out, and glued them to the blanks today. All of those dimensions came out perfect.
