We are finally happy with the way the canopy fits to the C702 skin when pulled tight. Confirmed the center line and the aft window "do not cut" line. Started the canopy cut from the center and worked outward taping the canopy together every eight inches. We didn ont cut the tail off the aft section. A pretty straight cut on the forward portion of the canopy however the aft portion will need tweaking.
After placing cut canopy on frame, we pulled canopy down to mark cut lines at Wd 725 joggle. Cut sides and test fit again. Additionl cutting will be required to get the canopy behind the ears of the C702 skin
