Obtained a 1 ton press from Harbor Freight and started working on fuselage F21 sheet. Preped bulkhead 5 cleco, updrill, debur and rivet. Used CCP 46 rivets on area where verticals are located as per updated plan revision. Took care of splice plates including bends indicated in the plans. I updrilled to #40 for initial clecoing and sanded splice plates smooth.
Bulkhead 5
Bulkhead 5 rivieted along with splice plates bend and sanded smooth
