I created 'L' pieces to attach 65T3-2 to 65T3-1 L&R. I miss measured the first time and had to remake them. 2nd time worked great. I set the center rib assembly into the skin and cleco'd assembly in place. looks like a good fit. Next will be disassembling the unit and deburring the skin and all of the ribs. I will reassemble it after that with cleco's. Then on to the horn assembly.
Notes: I wish this manual had been updated to 650. While everything in here is correct, some procedures need to be skipped or amended due to the pre-drill assemblies of the 650
