Davids Pipistrel Build Website
Date:  11-5-2017
Number of Hours:  16.00
Brief Description:  Completed power panel wiring
Added remaining labels to the front of the power panel, installed all the fuses and fused switches. Followed my power plan and created a separate connection for each item that was fused on the panel. Used Molex Mini-fit Jr. connectors for everything except the higher current lights and usb power jack. Labeled all the connector using heat shrink tubing that works in the labeler I purchased. Used wire ties to tie all the wires to a metal bracket attached to the panel for this purpose. Also tied off all the wires for each connector together.
