Davids Pipistrel Build Website
Date:  7-31-2016
Number of Hours:  3.00
Brief Description:  Prepare motor mount for main nose gear
Installed bearing in plastic bearing holder with retaining clip. Used a wooden dowel that was a tiny bit smaller then the nose gear tube on the motor mount. Marked the dowel at the length of the nose gear strut (up to the lip on the strut). Inserted the plastic bearing holder into the nose gear tube and pounded the dowel on the floor holding the motor mount until the plastic bearing holder was pushed up inside the tube and the mark on the dowel lined up with the bottom of the strut. Drilled an indent (not all the way through) in the hole for the set screw to keep the plastic bearing holder from turning. Loctited and installed the set screw. Installed the steering control horn and locking nut on top of the strut again with Loctite.
