Davids Pipistrel Build Website
Date:  11-15-2015
Brief Description:  Ground right spar pin bushing
Noticed that both pins were difficult to insert into the right bushing of the right wing (the pin I had trouble removing) so I used the same rotary grinding wheel in my dremel to enlarge the rear part of that bushing so the pin slides easily in and out. Now tried mounting the wings again and the right pin still binds. Needs more grinding
