Davids Pipistrel Build Website
Date:  11-15-2015
Number of Hours:  1.50
Brief Description:  Ground out wing root pin
The right wing root pins were too snug (very difficult to get wing off after installing) so I looked at the pin bushing and it was obvious where material needed to be remove (the bronze was polished on the rear side of the bushing. Used a dremel with a grinding wheel to take a small amount of bronze off the rear side of the bushing, Tried the wings again, now both sides are snug but easily go on an come off.
