Davids Pipistrel Build Website
Date:  9-8-2019
Number of Hours:  1.00
Brief Description:  Added stickers to various controls and installed f
Pipistrel supplies stickers for flaps, prop control door latches, Airspeed placards etc. Added this to mark these various controls. Put foam (bicycle handle grip) on flap handle. The first one I ripped trying to "push" it on. That didn't work so I ended up rolling it over (turning it inside out) but it ripped, so I had to buy a new one. I didn't want to use a lubricant so I went online and found that you can use air pressure to install. So I made a fitting to connect my compressor hose to a 1/2" black pipe and that fit perfectly in one end of the handle bar grip, Appled about 20-30psi and when I started pushing it on the flap handle, that sealed the end enough that it started to expand and it slipped right on.
