Davids Pipistrel Build Website
Date:  7-29-2017
Number of Hours:  6.00
Brief Description:  Fixed cowl release screw in wrong location
Always double check your measurements. I drilled one of the upper cowl mounting screws in the wrong location (off by 10mm tword the front of airplane). Luckily, I caught it after I drilled 3mm holes. Decided to move the release screw mount so the edge of the large mount portion of the cowl release screw was lined up with the incorrectly drilled hole. That way it is only off by about 5mm and not very noticable. Still enough fuselage material to mount the bolt without it being weak
