Davids Pipistrel Build Website
Date:  8-18-2018
Number of Hours:  3.00
Brief Description:  Drilled holes on fuselage for Elevator servo
Temporarily installed main control bar under cockpit floor and connected pushrod between servo and main control bar. Positioned elevator servo in bottom of fuselage under cockpit floor and marked it's position. Removed mounting bracket from servo and re-positioned bracket back under floor in the position I marked. Used 90 degree angle drill attachment and short drill bits to drill through fuselage bottom using elevator servo mounting angle bracket as a guide.
