Davids Pipistrel Build Website
Date:  2-10-2018
Brief Description:  Attached straps to top of fuselage, cut slots for
Drilled 5mm holes in top of fuselage alongside route of parachute straps. Attached straps to top of fuselage using plastic tie wraps. Used silicon rubber to fill holes for plastic straps and holes where parachute straps go through fuselage. Marked location of strap to go through chunk of fuselage cut out to be used as the parachute cover. Ground slots deep enough for straps to be slightly compress when cover is mounted.
