Davids Pipistrel Build Website
Date:  1-21-2018
Brief Description:  Drilled hole in fuselage for rocket exhaust tube
Put rocket exhaust tube over rocket exhaust. Mark were tube contacts fuselage. Drill a ¼ inch hole in center of the mark made for the tube. Go to the outside of the fuselage and with a 38mm hole saw, cut a hole in fuselage using the ¼ inch hole as a center guide for the hole saw. Sanded the inside of the fuselage and outside of the tube where epoxy will be applied.
