Brief Description: Installed locknuts on both ailerons
Put loctite on the aileron hing pin bolt. Lubed up all the hing pins and re-installed aileron and tightened the bolt using a 8mm combination ratchet wrench getting one click on the ratchet per turn. Tightened until I felt it bind the aileron then backed it off a ½ turn.
