Manufactured ADSB coax antenna, connected up ADSB connector and antenna. Turned on ADSB, Dynons says it is on and communicating with ADSB but was not able to receive any stations. Could be an antenna problem or just the fact that it is in my garage and not getting a strong signal on the ground. I will have to debug further. After running Dynons for so long, battery is main battery is getting low. Dug out old 4 amp car batter charger and re-charged. Need to come up with better charging solution.
