Brief Description: Installed nose wheel centering springs
Springs are very strong so I split an eye to eye swivel in half and used a regular bolt to replace the eye bolt. This way I can attach the springs in their un-sprung state and then tighten the bolts to stretch the springs to the correct length. Drilled and attached mounting bracket, attached swivel, bolt and spring, tightened springs so it looked like the picture in the instructions.
